Author Topic: WDE ConnID  (Read 4146 times)
Offline jvallejos
WDE ConnID
« on: November 22, 2016, 12:48:37 PM »
Hi
How i can get ConnID from a WDE Extension?
Offline PeteHoyle
Re: WDE ConnID
« Reply #1 on: November 22, 2016, 01:55:57 PM »
If you cast your interaction to an InteractionVoice you can get the ConnId
[code] if (interaction is IInteractionVoice)
      IInteractionVoice iiv = interaction as IInteractionVoice;
      string connId = interaction.TConnectionId;[/code]
Offline jvallejos
Re: WDE ConnID
« Reply #2 on: November 22, 2016, 02:06:24 PM »
Thanks PeteHoyle ,
but dont work form mi
Error 4 'Genesyslab.Desktop.Modules.Core.Model.Interactions.IInteraction' no contiene una definición de 'TConnectionId'(NotFound) ni se encontró ningún método de extensión 'TConnectionId' que acepte un primer argumento de tipo 'Genesyslab.Desktop.Modules.Core.Model.Interactions.IInteraction' (¿falta una directiva de uso o una referencia de ensamblado?)
Re: WDE ConnID
« Reply #3 on: November 22, 2016, 02:19:29 PM »
Well, obvious message, you need to add a reference to that DLL module...
Offline jvallejos
Re: WDE ConnID
« Reply #4 on: November 22, 2016, 02:48:34 PM »
i have the reference for Genesyslab.Desktop.Modules.Core.Model.Interactions.IInteraction but TConnectionId is the problem
Later i fix do this
        public void Initialize()
            //aca se crea el listener para poder detectar las interaccions al momento de ejecurse
            interactionManager.InteractionEvent += new EventHandler<EventArgs<IInteraction>>(interactionManager_InteractionEvent);
    void interactionManager_InteractionEvent(object sender, EventArgs<IInteraction> e)
            IInteraction interaction = e.Value;
            switch (interaction.EntrepriseLastInteractionEvent.Id)
                  case EventEstablished.MessageId:
                        IInteractionVoice iiv = e as IInteractionVoice;
                        //i try next to sentences
                        MessageBox.Show("El ConnId es:" +iiv.TConnectionId);
                      // MessageBox.Show("El ConnId es:" +iiv.TConnectionId.ToString());
                break;
But i found this Exception
Application.DispatcherUnhandledException
System.Reflection.TargetInvocationException: Se produjo una excepción en el destino de la invocación. ---> System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
  en Genesyslab.Desktop.Modules.Custom.CustomModule.interactionManager_InteractionEvent(Object sender, EventArgs`1 e)
  en System.EventHandler`1.Invoke(Object sender, TEventArgs e)
« Last Edit: November 22, 2016, 03:06:39 PM by jvallejos »
Offline PeteHoyle
Re: WDE ConnID
« Reply #5 on: November 22, 2016, 05:19:48 PM »
You would need a reference to 'Genesyslab.Desktop.Modules.Voice'
And then:
using Genesyslab.Desktop.Modules.Voice.Model.Interactions;
Offline daniel_san
Re: WDE ConnID
« Reply #6 on: November 23, 2016, 03:35:01 PM »
During a voice call, the event interactionManager_InteractionEvent will be executed several times. Maybe sometimes the value is null, but on next event it´s not null.
You can try to do that:
      IInteractionVoice iv = interaction as IInteractionVoice;
            if(iv.TconnectionID!=null)
            //now you can work
I´m assuming, that you are working with Visual Studio, and not with another ide that not trigger some error before compilation.
Regards.
EDIT: what line are launching the error?
Offline jvallejos
Re: WDE ConnID
« Reply #7 on: November 24, 2016, 04:49:19 PM »
Thanks Daniel san
With this line if(iv.TconnectionID!=null) work for me
