Author Topic: Search Interaction in iWD  (Read 2731 times)
Offline water235
« on: November 14, 2016, 09:20:18 PM »
is it possible to search interaction based on a custom KVP(or attached data ) in IWD.
Thanks!
Re: Search Interaction in iWD
« Reply #1 on: November 14, 2016, 10:17:47 PM »
Add it as a custom attribute and map to a IXN table column. Then modifiy the Templates to add this field.
Offline water235
« Reply #2 on: November 15, 2016, 08:51:29 PM »
Thanks for the reply, I m kind of really new, can you please elaborate a bit or provide any documentation for this.
Offline Dimitry
« Reply #3 on: November 16, 2016, 10:44:14 AM »
The IXN DB comes with predefined columns. If you cannot fit in the work item attribute to the existing columns you can define a custom attribute and add it as a separate column . You can store the custom KVP to the custom column . With that you can initiate a search.
« Reply #4 on: November 16, 2016, 02:07:48 PM »
Documentation is as always on support.genesyslab.com
Then on eServices you search for Make custom Attributes searchable
