Author Topic: Exporting and Importing VTO Scripts?  (Read 3384 times)
Tony Tillyer
I have a requirement to chnage all of my VTO Scipts and then change them back again (for testing and then back to production).
SO that I only have to make the changes once, is there any way of exporting the full VTO Script and then reimporting it, to overwrite the changes I would make in the meantime?
I don't see it anywhere and I've searched almost all of the Tables in SQL to see if I can extract them there.
Any help much appreciated!
TIA
Tony
DBM
  • You could export your whole Config database then re import it but you would lose any other changes made
    Tony Tillyer
  • I thought of this one too. We've decided to change the bare minimum in VTO then change it back again, after testing.
    Does anyone else find the fact that you can't export and import VTO Scripts irksome?
