Author Topic: Errors SCEE005 and SCEE006  (Read 5714 times)
Zygis
Can You say for me what is mean this twoo errors:
First:
SCEE005
The link to the Configuration Database is not available. Contact the network administrator.
Even though no modifications can be made until the link is restored, the Configuration Database contents still can be viewed. After the link has been restored, work can proceed without restarting Configuration Manager.
Second:
SCEE006
A database error has occurred. Try the same transaction again. If the problem persists, contact the network administrator.
I can't do anythind because I always getting this errors.
Then from DB it delete, I can work.
Where can be problems?
We are using G5.1.
gauthier
  • SCEE005 means that config server has lost connection to the Configuration Database. Check the DBServer to see it is running. If it is check your network connections and configurations if the 2 are not on the same host.
