Author Topic: Log for Login/Logout  (Read 3822 times)
Matt
We have a few superadmins in Config Manager that can change the config for daily use. Is there a way to log (or track) who logs in and out of Config Manager,SCI, etc.??
Ritchie
  • You can see them in Config Server logs. So you could write something to extract the relevant information....possibly?
    Tony Tillyer
  • Stranger is that Genesys haven't developed a licence manager for any of the Genesys Suite.
    Weird!
    Bill
  • If you have the debug level of logging set to write to a plain text file, then you will be able to see all the login/logout events of users of configuration manager, ir_designer, ccpulse, agent desktops. To find the events would require you have access to the plain text file, and time to filter through all the log events.
    Tony Tillyer
  • Would it be easier (if you are using it) to run a CCA/DMA/Brio Report against the Log In / Log Out details to provide a report, rather than sifting through log files?
