Author Topic: Detailed Login/Logout Report  (Read 3270 times)
Tony
Does anyone know how to create a detailed Login/Logout report in Brio that will tell you the exact time when an agent logs in and out of the phone in time format HH:MM:SS?
John Doe
  • Use the Stat Server tables but I believe Brio is only licensed for CCA.
    Superglide
  • Our vendor told us it was included.
    Zilan
  • Some details in table "Agent_Login" might help. Somehow my report display both agent current and old on the same row (I'm reusing agent id).
