Author Topic: Reject one call in WDE  (Read 4021 times)
Offline Ricktn
« on: July 26, 2016, 04:50:38 PM »
I need help about reject one call in WDE  if It is an agent,in the event of interaction I think I can validate the nomenclature of origin and reject the call, but can not find the line of code to do so.
if someone has already done something like that really help me a lot.
regards,
R.T.
Re: Reject one call in WDE
« Reply #1 on: July 27, 2016, 01:23:08 PM »
I am not sure what you want to achieve - could you please explain your needs with deep detail?
« Reply #2 on: July 27, 2016, 01:24:58 PM »
Also I would think to do that before Distribution at the strategy level, not at Agent side.
Offline Ricktn
« Reply #3 on: July 27, 2016, 04:58:36 PM »
Hello cavagnaro/Kubig,
Basically what is required is to restrict calls between agents , perform unsuccessfully in AgentDesktop settings in the options:
  -Intercommunication.voice.routing -based- targets = Agent
  -Intercommunication.voice.routing -points = RP@switchname
the most that was achieved can prevent see the names of the agents with:
  -teamcommunicator.list -filter -showing
But when dialing by extension the call comes and it should not be.
thaks, regards.
R.T.
Offline hsujdik
« Reply #4 on: July 27, 2016, 06:17:43 PM »
If you have consistent numbering on your environment, a dial plan on SIP Server should help you on this
Offline Ricktn
« Reply #5 on: August 11, 2016, 07:00:37 PM »
Is correct hsujdik, i solved with calling plan.
thank you very much to all.
