Author Topic: Need Help in Understanding the Unity Genesys exception information  (Read 5269 times)
Offline Vegeta
Hello Genesys Wizards,
Request your help and guidance to deal with the below exception while calling Genesys exe from C# cmd line, when I try it from local command prompt ( Just the  finalpath string in below code ) it works perfectly but if I do the same via code, I am receiving an exception [ Bottom of this post ]
I have googled the exception , but couldn't really make out what does it mean , could someone please help me understand what does this exception mean?
[code]private void LaunchWDE(string place,string csProxyUrl,string wdeAppName,int portNumber)
            try
          string    finalpath = @"C:\PATH\InteractionWorkspace.exe -url tcp://<HOST>:<PORT>/<APPLICATIONNAME> -u <USERNAME> -p <PASSWORD> -place <PLACE/LOGINID>";
                ProcessStartInfo procStartInfo = new ProcessStartInfo("cmd", "/c " + finalpath);
                procStartInfo.RedirectStandardOutput = true;
                procStartInfo.UseShellExecute = false;
                procStartInfo.CreateNoWindow = true;
                System.Diagnostics.Process proc = new System.Diagnostics.Process();
                proc.StartInfo = procStartInfo;
                proc.Start();
                string result = proc.StandardOutput.ReadToEnd();
                this.Close();
            catch(Exception ex)
                MessageBox.Show("Error while launching WDE" + ex.Message + " " + ex.InnerException);
            } [/code]
Exception ::
Microsoft.Practices.Unity.ResolutionFailedException was unhandled
Message: An unhandled exception of type 'Microsoft.Practices.Unity.ResolutionFailedException' occurred in Microsoft.Practices.Unity.dll
Additional information: Resolution of the dependency failed, type = "Genesyslab.Desktop.Infrastructure.IBootstrapController", name = "". Exception message is: The current build operation (build key Build Key[Genesyslab.Desktop.Infrastructure.IBootstrapController, null]) failed: The current type, Genesyslab.Desktop.Infrastructure.IBootstrapController, is an interface and cannot be constructed. Are you missing a type mapping? (Strategy type BuildPlanStrategy, index 3)
Offline Vegeta
Re: Need Help in Understanding the Unity Genesys exception information
« Reply #1 on: July 15, 2016, 07:23:48 AM »
@ All, after some googling efforts and a tip from Genesys Support.
I was able to finally launch the WDE instance from C# code... with arguments attached.
Tip from Genesys:
# Try to set the Directory path to the WDE installation ( I tried previously by passing whole path in string but that wasn't so useful).
If it might benefit others.. just pasting the working code for reference..
[code]
  string Path = "C:\Program Files\GCTI\Workspace Desktop Edition\InteractionWorkspace";
                Directory.SetCurrentDirectory(Path);
                ProcessStartInfo procStartInfo = new ProcessStartInfo();
                procStartInfo.FileName = "InteractionWorkspace.exe";
                procStartInfo.Arguments = @"-url tcp://<HOST>:<PORT>/<APPLICATIONNAME> -u <USERNAME> -p <PASSWORD> -place <PLACE/LOGINID>";
  // The following commands are needed to redirect the standard output.
// Now we create a process, assign its ProcessStartInfo and start it
                proc.Start();
[/code]
« Reply #2 on: July 15, 2016, 12:53:52 PM »
And...what is this for? What you did?
Offline Vegeta
« Reply #3 on: July 28, 2016, 08:35:09 AM »
[quote author=cavagnaro link=topic=9713.msg44065#msg44065 date=1468587232]
Hi Cavagnaro, Sorry abt a delayed reply...
My objective was to open WDE without launching it via direct executable file.
* I initially tried to call the WDE via command prompt (along with Host/port/Username/passw/place details passed as command arguments).
Ex: Open Command prompt > goto the WDE dir path and use the below Command line input..
-url tcp://<HOST>:<PORT>/<APPLICATIONNAME> -u <USERNAME> -p <PASSWORD> -place <PLACE>
* with aforesaid approach I was able to prove WDE can be invoked via command line.
* In my original post , the pseudo code I shared was trying to open a command prompt and do the same via .Net code.
* While doing so I got the Exception , to which I reached out for Genesys support help and they suggested to
set the  Directory.SetCurrentDirectory(WDE_INSTALLATION_PATH) to avoid the exception.
In my follow-up post I shared the latest code where I have tweaked a few lines ( Instead of opening a command line and passing the command line input syntax, I used createprocess functions to launch WDE  from code) along with Genesys Suggestion incorporated.
Just wanted to share it across , if it might benefit someone who could run into similar errors.
Thanks.
« Reply #4 on: July 28, 2016, 11:12:25 AM »
Thanks for such detailed answer
Good luck!
