" /> Consume "Dictionary ConfigApplication" Values read when WDE loads within code - Genesys CTI User Forum
Author Topic: Consume "Dictionary ConfigApplication" Values read when WDE loads within code  (Read 2999 times)
Offline Vegeta
Mighty Genesys Wizards,
Request your help to understand if there is any feasibility to read below within WDE code without opening a Config Server Object within code?
1. When I look into InteractionWorkspace.logs , I could see that WDE Is reading the below values [Have pasted a Extract]
[code]#############################  Dictionary ConfigApplication #############################
'<media-type>.auto-answer'        ='false'
'<media-type>.auto-answer.enable-reject'                                                  ='false'
...//Arul -- some Config Values
'keyboard.shortcut.action.help'                                                            ='F1'
[/code]
is there any code feasibility to read these parameters in a any collection obj or any other obj within the WDE code?
i.e can I somehow read the same values eg: ( 'keyboard.shortcut.action.help' ='F1') without creating a new Config object , opening a connection etc?
Reason I am saying without a new config obj being created is that - if WDE is able to read this value while its loading can we not consume it readily in code somehow?
Please advice.
Maybe if you look at WDE source code and find the variable that holds it and somehow fork it to your code
Offline Vegeta
Many Thanks for the advice. I was able to find some clue what it was doing during load also some of the Genesys community posts helped me out.
Just if it might benefit others - typing how I was able to consume it.
I found that its reading those entries from one of CME options under my Application name.
So I used the below property within my constructor to get those shortcuts and some other custom options..
MyApplication = Gets the configuration application.
Declaration Syntax = CfgApplication MyApplication { get; }
[code]
IConfigurationService configService = container.Resolve<IConfigurationService>();
  app = configService.MyApplication;
  Platform.Commons.Collections.KeyValueCollection cme = (Platform.Commons.Collections.KeyValueCollection)app.Options["OPTION NAME"];
[/code]
Thanks for sharing
