" /> how to retreive workbin interaction - Genesys CTI User Forum
Author Topic: how to retreive workbin interaction  (Read 2677 times)
Offline Naveen Kancharla
« on: June 17, 2016, 05:41:05 AM »
from the below code i can retrieve workbin but unable to retrieve interaction in it.
          CfgScriptQuery csq = new CfgScriptQuery();
            csq.ScriptType = CfgScriptType.CFGInteractionWorkBin;
            ICollection<CfgScript> cs = confservice.RetrieveMultipleObjects<CfgScript>(csq);
kindly suggest some psdk with sample example.
« Last Edit: June 17, 2016, 06:41:14 AM by Naveen Kancharla »
Re: how to retreive workbin interaction
« Reply #1 on: June 17, 2016, 11:59:40 AM »
Your code just retreieve the configuration objects, but not work with UCS/IXN at all.
Offline Gabi
« Reply #2 on: July 19, 2016, 04:07:21 PM »
I think what you're looking for is RequestPull (com.genesyslab.platform.openmedia.protocol.interactionservice.requests.interactionmanagement.RequestPull).
Here's an example of how to use it:
[code]
RequestPull req = RequestPull.create();
KeyValueCollection pullParameters = new KeyValueCollection();
pullParameters.addString("InteractionId", interactionId);
req.setPullParameters(pullParameters);
req.setViewId("_system_");
Message ret = interactionServerProtocol.request(req);[/code]
