" /> Difference between Agent Group and DN group - Genesys CTI User Forum
Author Topic: Difference between Agent Group and DN group  (Read 1804 times)
Offline Dimitry
« on: May 25, 2016, 06:23:05 AM »
Hi ,
I am quiet new to Genesys. Could you please let me know what is the difference between agent Group and DN group ? How would this help in terms of Stat server application ?
Offline Dionysis
Re: Difference between Agent Group and DN group
« Reply #1 on: May 25, 2016, 06:45:14 AM »
Agent group contains agents, and a DN group contains DN's.
So stat server can monitor a group of DN's using a DN Group, or a group of agents using an Agent Group.
Offline Dimitry
« Reply #2 on: May 25, 2016, 06:58:38 AM »
Thanks Dionysis
So when I have to calculate the number of agent logged of specific skill type , number of agent in calls now etc I should collect the stats against the agent group  . So the stat server will give the sum of all agent details right ?
When I have to calculate the number of calls entered to the particular group , number of calls that has abandoned , the stats can be taken from DN group .. right ?
Offline Dionysis
« Reply #3 on: May 25, 2016, 08:24:37 AM »
That's correct.
