" /> WFM stat server - Genesys CTI User Forum
Author Topic: WFM stat server  (Read 2756 times)
Offline Leonxxx86
WFM stat server
« on: May 23, 2016, 12:58:49 AM »
How can I tell when the WFM SS has been switched from the primary to the backup? I'd like to know when did the switch happened? Thanks
Re: WFM stat server
« Reply #1 on: May 23, 2016, 07:44:27 AM »
You can observe the occurences of standard alarm/log messages related to HA configuration - as the component role being changed, etc. Check the LMS file
Re: WFM stat server
« Reply #2 on: May 23, 2016, 11:13:18 AM »
Scs logs, alarms if configured, SS own logs...
Offline hsujdik
Re: WFM stat server
« Reply #3 on: May 23, 2016, 01:58:32 PM »
Personally, I find the LCA logs the easier place to look for switchovers. It logs all the applications' status and workmode changes on each server. But all the above mentioned logs are also good places to look at
Offline Leonxxx86
Re: WFM stat server
« Reply #4 on: May 23, 2016, 10:56:34 PM »
Awesome! thanks all
