Author Topic: Get TServerProtocol in WDE  (Read 2944 times)
Offline Alyw
« on: May 16, 2016, 01:15:05 AM »
I need to get a value from the user data in a specified event, so that I can decide what to be displayed in the WDE. How can I get the TServerProtocol in WDE?
Offline javiaf
Re: Get TServerProtocol in WDE
« Reply #1 on: May 19, 2016, 12:31:42 PM »
Hi Alyw,
Hope this helps. I guess you will have an IAgent object:
[i]IAgent agent[/i] (You can get it in any WDE registered class using DependencyInjection).
Afterwards, we check both, if FirstMediaVoice and Channel are not null... In that case, we can get the TServerProtocol.
[i]            if (agent.FirstMediaVoice != null)
                channel = agent.FirstMediaVoice.Channel;
                if (channel != null)
                    TServerProtocol tserver = (TServerProtocol)channel.Protocol;
[/i]
Regards!
« Last Edit: May 19, 2016, 12:33:24 PM by javiaf »
Offline daniel_san
« Reply #2 on: June 03, 2016, 03:10:21 PM »
[quote author=Alyw link=topic=9602.msg43352#msg43352 date=1463361305]
Why you need TServerProtocol to Show/Hide some part of WDE? Maybe you can try another way (more simple).
Regards.
