" /> Watchdog not starting - Genesys CTI User Forum
Author Topic: Watchdog not starting  (Read 2897 times)
Offline Fabrice
« on: May 13, 2016, 12:00:52 PM »
Hi , in development server, we have some apps and one such app is Watchdog. This server is failing to start. When I attempt to start from Windows services(services.msc), the error message I get is "The service started and then stopped. Some service stop if they have no work to do like Performance and Log Alerts service". Because of this IVR service is also down. Hence I cant hear any IVR playing while making test call. Please help. This is affecting my dev task.
Offline Tambo
Re: Watchdog not starting
« Reply #1 on: May 13, 2016, 12:51:54 PM »
you need to supply logs of watchdog
Offline Tambo
« Reply #2 on: May 17, 2016, 09:04:07 AM »
Upload your logs to service like Megaupload, Rapishare and post the link.
hope this helps
Offline thmuche
« Reply #3 on: May 17, 2016, 12:05:27 PM »
Sometimes when you stop the WatchDog service the application don't finalize in Java and you need kill the java instance in Windows task manager and after start the WatchDog in Windows Service. Try this..
Offline Defender451
« Reply #4 on: May 20, 2016, 09:40:54 PM »
Try restarting the Nuance services then try to start.
Offline hsujdik
« Reply #5 on: May 22, 2016, 02:48:59 AM »
Also, try to start up from a command prompt instead of services. This might give a clue on what happened. There was one time that none of the logs helped, but starting WatchDog from command line gave the hint that in fact the AntiVirus had deleted a dll from the IPCS folder.
