" /> How Chain of command working... - Genesys CTI User Forum
Author Topic: How Chain of command working...  (Read 3209 times)
Offline bhuvanesh
« on: April 29, 2016, 07:42:00 AM »
It's very awesome that the way chain of command works, I very curious to know how it works and what's the concept behind it.. Can any one share knowledge.
Thanks in advance.
Re: How Chain of command working...
« Reply #1 on: April 29, 2016, 10:56:27 AM »
What are you talking about? Which product?
« Reply #2 on: May 02, 2016, 05:43:45 AM »
I think he means the commands within the IWS/WDE application. In this case, the used pattern is MVVM - so, if you want to know more, just look how this pattern works (.Net)
Offline bhuvanesh
« Reply #3 on: May 02, 2016, 09:38:28 AM »
Thanks for responding guys,
Yes in WDE/IWS Application Genesys uses the concept of Chain of Command which is not relevant to MVVM pattern of course MVVM pattern is used in WDE but Chain of command is different.
« Reply #4 on: May 02, 2016, 10:14:43 AM »
So, jsut use the reverse engineering
Offline abudwill
« Reply #5 on: May 10, 2016, 09:05:38 AM »
In IWS/WDE - chain of commands is just various commands (code) that are linked together to run one after the other in order.  If one command fails, the subsequent commands in the chain are not executed.
Genesys support site has them documented pretty well.
Take for example whatever chain executes when an interaction closes.  There are commands that execute like, "IsPossibleToCloseInteraction", a reason this might fail is if something like a required disposition is not selected.
You can insert your own commands at any position in a command chain.
On occasion some chains are not documented.  Turn IWS/WDE logging to full, perform the action in WDE and then examine IWS logs to see what chain / commands are executed.
