Author Topic: CCpulse View not available  (Read 3280 times)
Offline Leonxxx86
« on: April 29, 2016, 12:21:35 AM »
I have this issue in CCpulse which when I open the workspace and select "test" it loaded but nothing appear in object only white page, SS that I used is the same one I used for the other workspace which opens fine only the test workspace, could you please help?
Re: CCpulse View not available
« Reply #1 on: April 29, 2016, 01:52:16 AM »
Can you post a screnshot?
Offline Leonxxx86
« Reply #2 on: April 29, 2016, 02:47:16 AM »
For some reason I can't attached the screenshot here I get this [img ][/img ] when I click on insert image.
« Last Edit: April 29, 2016, 02:50:50 AM by Leonxxx86 »
Offline nonny
« Reply #3 on: April 29, 2016, 09:24:45 AM »
Are you saying the objects view is blank?  Are you sure it's in Objects view and not Views or Extended Status?
If you see objects but views aren't loading, do both workspaces use the same templates?
Sent from my SM-N9005 using Tapatalk
Offline Tambo
« Reply #4 on: April 29, 2016, 09:50:59 AM »
have you ticked...........objects and views etc in the view tab top left of your ccpulse page?
« Reply #5 on: April 29, 2016, 10:55:51 AM »
You must post on external file server and share the link with us
Offline nonny
« Reply #6 on: May 08, 2016, 08:26:40 AM »
No longer an issue?
Offline Tambo
« Reply #7 on: May 09, 2016, 03:08:36 PM »
excellent resolution description !!
