Author Topic: Cannot login while forwarding set  (Read 3454 times)
Offline Leonxxx86
« on: April 28, 2016, 02:42:30 AM »
Agent not able to login and when i looked in t server CUCM I found the below error message, can someone please advise how to resolve the issue? Thanks
@11:37:19.9930 [gctm] TMsg [RequestAgentLogin(xxxxx)] Generating EventError [700: 'Cannot login while forwarding set']
Re: Cannot login while forwarding set
« Reply #1 on: April 28, 2016, 03:05:34 AM »
On the Cisco remove/disable the forwarding set feature. Should be a prefix, ask your Cisco guys.
Offline Leonxxx86
« Reply #2 on: April 28, 2016, 03:14:10 AM »
Thanks cavagnaro for your quick reply!
Offline Leonxxx86
« Reply #3 on: April 28, 2016, 11:42:15 PM »
I have checked with the Cisco guys, they advised there is no call forwarding on the DN. Can you please advise? Thanks
« Reply #4 on: April 28, 2016, 11:53:16 PM »
That message is coming from your Cisco, so ask them to verify that DN. Must have something wrong with it
Offline Leonxxx86
« Reply #5 on: April 28, 2016, 11:58:24 PM »
Thanks cavagnaro, I'll check with them again. I was thinking to delete the DN from CME and create it again?
« Reply #6 on: April 29, 2016, 01:51:27 AM »
Can try, might be also a bad status stuck on TServer, can try to disable/enable again
Offline nonny
« Reply #7 on: April 29, 2016, 02:28:18 AM »
Make sure it's not set to forward to voicemail specifically
Sent from my SM-N9005 using Tapatalk
Offline nonny
« Reply #8 on: April 29, 2016, 02:28:52 AM »
What happens if you call the phone?
Offline Leonxxx86
« Reply #9 on: April 29, 2016, 02:49:02 AM »
It was set to forward to VM before but we disabled it. I have deleted the DN from CME and created it again and that fixed it. Thanks
