Author Topic: Composer Help  (Read 1864 times)
Offline water235
Composer Help
« on: April 27, 2016, 08:22:36 PM »
I m trying get it going with composer, and i see most of the learning for composer is based on the multimedia routing, is there any pointer where i can see an example of voice application development. Also is there a good guide that would let us go over the process of learning the composer based routing.
Any directions regarding this is highly appreciated.
Thanks.
Re: Composer Help
« Reply #1 on: April 27, 2016, 08:50:46 PM »
Nope, just training or testing.
While you develop check the block help file. Will help a lot.
Also on composer there are some templates with samples on it, maybe you can try to check those as well.
