Author Topic: Logs  (Read 2497 times)
Offline Leonxxx86
Logs
« on: April 20, 2016, 06:14:13 AM »
There is this .snapshot in the logs for different Genesys application, what is the snapshot for and why the app generate it? Thanks
Re: Logs
« Reply #1 on: April 20, 2016, 08:15:07 AM »
[quote]The snapshot log that is actively being used will have the application's startup date & time within its filename
This snapshot log is removed when the Genesys application is shut down properly & does not shutdown due to crash
If the Genesys application crashes, this snapshot log file will likely not be removed and also will be very important for Genesys's analysis as it will show the very last item being processed just prior to the crash[/quote]
Offline Leonxxx86
Re: Logs
« Reply #2 on: April 21, 2016, 12:23:30 AM »
Thanks Kubig,
What if the primary app switch to back up, will there be snapshot log generated?
Re: Logs
« Reply #3 on: April 21, 2016, 02:10:55 AM »
Snapshot, as mentioned is created when the service starts. And deleted only with proper stop.
Offline Leonxxx86
Re: Logs
« Reply #4 on: April 21, 2016, 11:32:33 PM »
