Author Topic: IRD 7.5 DB Wizard for function (not procedure) inside a package (Oracle)  (Read 1887 times)
Offline Gef Buneri
  • Madness is just a point of view.
Hi all, I'm facing a quite tricky challenge.
Usually I manage to recall functions out of a package or a procedure inside/outside package, but I'm facing troubles invoking a function inside a package; for procedures, I usually use package.procedure, but seems this method does not works with package.function.
Any tip?
Best regards,
Gef.
***EDIT***
No way out, I had to convert it in a procedure, to make it work. In URS logs (7.5), variables seems to be given to the function, but actually no transaction is registered from the function itself.
« Last Edit: April 19, 2016, 11:52:21 AM by Gef Buneri »
