Author Topic: Retrieving connection to database for pulse failed. Using Gax 8.5.220  (Read 3602 times)
Offline kny
Hi everyone, I am getting error after installing pulse plugin with GAX. Gax works fine but i cannot see the pulse plugin, Can anyone help me please,
here is my GAX log,
Extension Log File
Version: 8.5.220.20
Hostname: MU1-VM-DBS-02
JVM vendor: Java HotSpot(TM) 64-Bit Server VM version:Java HotSpot(TM) 64-Bit Server VM
2016-03-30 10:45:52,442 WARN : com.genesyslab.gax.core.audit.AuditDatabaseBeanManager [main] - [49] Auditing data source is not configured, auditing is disabled!
2016-03-30 10:45:58,042 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [179] ------------------------------------------------------------
2016-03-30 10:45:58,045 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [180] GAX - MS configuration.
2016-03-30 10:45:58,077 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [201] Timeout in seconds between attempts = 60
2016-03-30 10:45:58,077 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [218] Maximum number of connection attempts = 1
2016-03-30 10:45:58,077 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [221] Maximum number of configured switchovers trials = unlimited
2016-03-30 10:45:58,090 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [235] Starting Warmstandby Service
2016-03-30 10:45:58,090 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [237] Warmstandby Service started.
2016-03-30 10:45:58,175 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [179] ------------------------------------------------------------
2016-03-30 10:45:58,175 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [180] GAX - SCS configuration.
2016-03-30 10:45:58,200 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [201] Timeout in seconds between attempts = 60
2016-03-30 10:45:58,202 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [218] Maximum number of connection attempts = 1
2016-03-30 10:45:58,202 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [221] Maximum number of configured switchovers trials = unlimited
2016-03-30 10:45:58,210 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [235] Starting Warmstandby Service
2016-03-30 10:45:58,212 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [237] Warmstandby Service started.
2016-03-30 10:45:58,222 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [154] Opening connection to SCS Server ...
2016-03-30 10:45:58,340 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [154] Opening connection to MS Server ...
2016-03-30 10:45:58,755 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [179] ------------------------------------------------------------
2016-03-30 10:45:58,862 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [180] GAX - LCA configuration.
2016-03-30 10:45:58,880 INFO : com.genesyslab.gax.core.configuration.messageserver.MSChannelListener [Thread-11] - [22] Event:Channel tcp://MS@172.31.182.50:4044 is opened.
2016-03-30 10:45:58,880 INFO : com.genesyslab.gax.core.configuration.scs.SCSConnectorChannelListener [Thread-10] - [22] Event:Channel tcp://SCS@172.31.182.50:4046 is opened.
2016-03-30 10:45:58,902 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [201] Timeout in seconds between attempts = 60
2016-03-30 10:45:58,902 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [206] Timeout for LCA = 1000
2016-03-30 10:45:58,902 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [218] Maximum number of connection attempts = 1
2016-03-30 10:45:58,902 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [221] Maximum number of configured switchovers trials = unlimited
2016-03-30 10:45:58,917 ERROR: com.genesyslab.gax.core.configuration.warmstandby.utils.WarmStandbyImpl [main] - [71] Wrong port configuration for Configuration object: type = CfgApplication, properties = {
    DBID : 253
    password : [output suppressed]
    type : CFGGenesysAdministratorServer
    version : 8.5.2
    appServerDBIDs : StructList(CfgConnectionInfo)[6] = {
        Configuration object: type = CfgConnInfo, properties = {
            appServerDBID : 99
            connProtocol : addp
            timoutLocal : 20
            timoutRemote : 20
            mode : CFGTMBoth
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 103
            timoutLocal : 0
            timoutRemote : 0
            mode : CFGTMNoTraceMode
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 104
            timoutLocal : 0
            timoutRemote : 0
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 254
            timoutLocal : 0
            timoutRemote : 0
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 255
            timoutLocal : 0
            timoutRemote : 0
            mode : CFGTMNone
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 261
            timoutLocal : 0
            timoutRemote : 0
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
    tenantDBIDs : ConfIntegerCollection[1 item(s)] = {
    [1-1]: 101
    isServer : CFGTrue
    serverInfo : Configuration object: type = CfgServer, properties = {
        hostDBID : 106
        backupServerDBID : 0
        timeout : 10
        attempts : 1
    options : KVList:
    'arm' [lst] = KVList:
    'delete_from_db_after_processing' [str] = "false"
    'local_announcement_folder' [str] = "announcement"
    'local_music_folder' [str] = "music"
    'local_path' [str] = "/opt/gax/arm"
    'local_sox_path' [str] = "/usr/bin/sox"
    'max_upload_audio_file_size' [str] = "20"
    'target_announcement_folder' [str] = "announcement"
    'target_music_folder' [str] = "music"
    'target_path' [str] = "/mnt/arm/target"
    'asd' [lst] = KVList:
    'local_ip_cache_dir' [str] = "./plugin.data/asd/gaxLocalCache"
    'silent_ini_path' [str] = "./plugin.data/asd/installation/genesys_silent_ini.xml"
    'clog' [lst] = KVList:
    'maxlogs' [str] = "5000"
    'minlogs' [str] = "100"
    'ga' [lst] = KVList:
    'ga_appName' [str] = "default"
    'ga_host' [str] = ""
    'ga_port' [str] = "80"
    'ga_protocol' [str] = "http"
    'general' [lst] = KVList:
    'auditing' [str] = "true"
    'client_app_name' [str] = "default"
    'default_account_dbid' [str] = "100"
    'inactivity_timeout' [str] = "600"
    'msgsrv_attempts' [str] = "1"
    'msgsrv_timeout' [str] = "10"
    'msgsrv_warmstandby_timeout' [str] = "60"
    'scs_attempts' [str] = "1"
    'scs_timeout' [str] = "10"
    'scs_warmstandby_timeout' [str] = "60"
    'session_timeout' [str] = "900"
    'log' [lst] = KVList:
    'all' [str] = ""
    'standard' [str] = "stdout,./logs/gax.log"
    'trace' [str] = ""
    'verbose' [str] = "standard"
    'opm' [lst] = KVList:
    'write_json' [str] = "false"
    'pulse' [lst] = KVList:
    'cache_expire_timeout' [str] = "1200"
    'editable_templates' [str] = "false"
    'health_expire_timeout' [str] = "30"
    'install_templates' [str] = "true"
    'max_widgets_per_user' [str] = "0"
    'snapshot_expire_timeout' [str] = "24"
    'security' [lst] = KVList:
    'host_whitelist' [str] = "172.31.182.55"
    'host_whitelist_enabled' [str] = "true"
    state : CFGEnabled
    userProperties : KVList:
    appPrototypeDBID : 151
    flexibleProperties : KVList:
    workDirectory : .
    commandLine : .
    autoRestart : CFGFalse
    startupTimeout : 90
    shutdownTimeout : 90
    redundancyType : CFGHTColdStanby
    isPrimary : CFGTrue
    startupType : CFGSUTAutomatic
    portInfos : StructList(CfgPortInfo)[0] = {
    resources : StructList(CfgObjectResource)[0] = {
    componentType : CFGAppComponentUnknown
2016-03-30 10:45:58,922 ERROR: com.genesyslab.gax.core.configuration.warmstandby.utils.WarmStandbyImpl [main] - [74] Wrong port configuration for Configuration object: type = CfgApplication, properties = {
    DBID : 253
    version : 8.5.2
            appServerDBID : 99
            connProtocol : addp
            timoutLocal : 20
            timoutRemote : 20
            mode : CFGTMBoth
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 103
            timoutLocal : 0
            timoutRemote : 0
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 104
            timoutLocal : 0
            timoutRemote : 0
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 254
            timoutLocal : 0
            timoutRemote : 0
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 255
            timoutLocal : 0
            timoutRemote : 0
            mode : CFGTMNone
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
            appServerDBID : 261
            timoutLocal : 0
            timoutRemote : 0
            longField1 : 0
            longField2 : 0
            longField3 : 0
            longField4 : 0
    [1-1]: 101
    isServer : CFGTrue
        hostDBID : 106
        timeout : 10
        attempts : 1
    options : KVList:
    'all' [str] = ""
    'trace' [str] = ""
    state : CFGEnabled
    workDirectory : .
    commandLine : .
    startupTimeout : 90
    isPrimary : CFGTrue
2016-03-30 10:45:58,930 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [154] Opening connection to LCA Server ...
2016-03-30 10:45:58,977 WARN : com.genesyslab.gax.core.system.SystemConfigurationImpl [main] - [145]
GAX starts with following command line:
null
GAX (application dbid: 253) is configured with the following options:
arm/delete_from_db_after_processing: 'false'
arm/local_announcement_folder: 'announcement'
arm/local_music_folder: 'music'
arm/local_path: '/opt/gax/arm'
arm/local_sox_path: '/usr/bin/sox'
arm/max_upload_audio_file_size: '20'
arm/target_announcement_folder: 'announcement'
arm/target_music_folder: 'music'
arm/target_path: '/mnt/arm/target'
asd/local_ip_cache_dir: './plugin.data/asd/gaxLocalCache'
asd/silent_ini_path: './plugin.data/asd/installation/genesys_silent_ini.xml'
clog/maxlogs: '5000'
clog/minlogs: '100'
ga/ga_appname: 'default'
ga/ga_host: ''
ga/ga_port: '80'
ga/ga_protocol: 'http'
general/auditing: 'true'
general/client_app_name: 'default'
general/default_account_dbid: '100'
general/inactivity_timeout: '600'
general/msgsrv_attempts: '1'
general/msgsrv_timeout: '10'
general/msgsrv_warmstandby_timeout: '60'
general/scs_attempts: '1'
general/scs_timeout: '10'
general/scs_warmstandby_timeout: '60'
general/session_timeout: '900'
log/all: ''
log/standard: 'stdout,./logs/gax.log'
log/trace: ''
log/verbose: 'standard'
opm/write_json: 'false'
pulse/cache_expire_timeout: '1200'
pulse/editable_templates: 'false'
pulse/health_expire_timeout: '30'
pulse/install_templates: 'true'
pulse/max_widgets_per_user: '0'
pulse/snapshot_expire_timeout: '24'
security/host_whitelist: '172.31.182.55'
security/host_whitelist_enabled: 'true'
2016-03-30 10:45:59,200 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [179] ------------------------------------------------------------
2016-03-30 10:45:59,215 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [180] GAX - SCS configuration.
2016-03-30 10:45:58,977 INFO : com.genesyslab.gax.core.configuration.lca.LcaMessageHandler [com.genesyslab.PCT.invoker.default] - [14] message received: 'EventHostUnderControl' (41) attributes:
attr_scs_socket [long] = 552
attr_scs_app_name [str] = "P_SolutionControlServer"
attr_scs_host_name [str] = ""
2016-03-30 10:45:59,212 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-13] - [23] Event:Channel tcp://LCA@localhost:4999 is opened.
2016-03-30 10:45:59,217 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-13] - [28] Event:updateStatus app name: gax
2016-03-30 10:45:59,220 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-13] - [29] Event:updateStatus status: Running
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-22] - [161] Plugin gax-core is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-14] - [161] Plugin gax-clog is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-15] - [163] Plugin gax-fim is running as a backend service
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-16] - [161] Plugin gax-webservice is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-17] - [161] Plugin gax-opm-arm is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-18] - [161] Plugin gax-ga is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-19] - [161] Plugin pulse is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-20] - [161] Plugin gax-com is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-21] - [161] Plugin gax-asd is enabled
2016-03-30 10:46:01,140 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [89] ---------- opm-arm Database Schema Version ----------
2016-03-30 10:46:01,200 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [90]                    8.1.301.01
2016-03-30 10:46:01,205 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [91] -------------------------------------------------
2016-03-30 10:46:01,205 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [41] Db Schema Version for plugin gax-opm-arm 8.1.301.01 is matching.
2016-03-30 10:46:01,207 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [43] ------------------------------------------------------------------------
2016-03-30 10:46:01,112 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [89] ---------- core Database Schema Version ----------
2016-03-30 10:46:01,220 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [90]                    8.1.301.01
2016-03-30 10:46:01,220 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [91] -------------------------------------------------
2016-03-30 10:46:01,222 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [41] Db Schema Version for plugin gax-core 8.1.301.01 is matching.
2016-03-30 10:46:01,230 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [43] ------------------------------------------------------------------------
2016-03-30 10:46:01,200 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [89] ---------- asd Database Schema Version ----------
2016-03-30 10:46:01,232 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [90]                    8.5.000.01
2016-03-30 10:46:01,237 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [91] -------------------------------------------------
2016-03-30 10:46:01,237 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [41] Db Schema Version for plugin gax-asd 8.5.000.01 is matching.
2016-03-30 10:46:01,260 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [43] ------------------------------------------------------------------------
2016-03-30 10:46:02,573 ERROR: com.genesyslab.gax.core.database.GAXBasicDataSource [Thread-19] - [29] ---------------------------------------------------------------------
2016-03-30 10:46:03,075 ERROR: com.genesyslab.gax.core.database.GAXBasicDataSource [Thread-19] - [30] Retrieving connection to database for pulse failed.
2016-03-30 10:46:03,425 ERROR: com.genesyslab.gax.core.database.GAXBasicDataSource [Thread-19] - [32] ---------------------------------------------------------------------
2016-03-30 10:46:05,130 WARN : com.genesyslab.gax.wbrt.dao.LayoutDaoImpl [Thread-19] - [405] Database check schema failed due to exception: Could not get JDBC Connection; nested exception is org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Network error IOException: Connection refused: connect)
2016-03-30 10:46:07,660 WARN : com.genesyslab.gax.wbrt.main.EZPulsePlugin [Thread-19] - [93] Db Schema Version for plugin pulse is not matching: expected version 8.5.001.02 but current is null
2016-03-30 10:46:07,660 ERROR: com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-19] - [190] Plugin pulse database schema version mismatch
2016-03-30 10:46:13,000 INFO : com.genesyslab.gax.asd.main.ASDPlugin [Thread-21] - [83] SPD setup: loaded default scripts
2016-03-30 10:46:13,495 INFO : com.genesyslab.gax.asd.main.ASDPlugin [Thread-21] - [102] ASD initialized
2016-03-30 10:46:26,848 INFO : com.genesyslab.gax.webservice.UserController [qtp1323468230-42] - [118] Client:172.31.182.43 try to login.
2016-03-30 10:46:27,028 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [256] Warmstandby.getstate: Idle
2016-03-30 10:46:27,028 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [com.genesyslab.PCT.invoker.warmstandby] - [318] Config Server warmstandby state changed to Idle
2016-03-30 10:46:27,033 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [257] Warmstandby service started
2016-03-30 10:46:27,033 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [366] Opening connection to endpoint 2mjlpp9cecmp1de4mfcburxoda - tcp://172.31.182.50:2020
2016-03-30 10:46:27,033 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [367] Trusted storage location: null
2016-03-30 10:46:27,036 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [368] TLS service properly initialized: false
2016-03-30 10:46:27,038 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [369] TLS Authentication mandatory: false
2016-03-30 10:46:27,213 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [com.genesyslab.PCT.invoker.default] - [338] Config server (tcp://2mjlpp9cecmp1de4mfcburxoda@172.31.182.50:2020) channel opened event. Endpoint: 2mjlpp9cecmp1de4mfcburxoda - tcp://172.31.182.50:2020
2016-03-30 10:46:27,604 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [com.genesyslab.PCT.invoker.default] - [359] Notifying waiting thread...
2016-03-30 10:46:31,261 INFO : com.genesyslab.gax.core.scs.AlarmService [coreExecutor-1] - [59] Registered to ActiveAlarms
2016-03-30 10:46:46,007 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [com.genesyslab.PCT.invoker.warmstandby] - [318] Config Server warmstandby state changed to Off
2016-03-30 10:46:46,009 INFO : com.genesyslab.gax.core.connection.ConfServiceProxyHandler [qtp1323468230-55] - [92] Connection to config server closed (User:default, Session:2mjlpp9cecmp1de4mfcburxod)
2016-03-30 10:46:46,012 INFO : com.genesyslab.gax.webservice.UserController [qtp1323468230-55] - [268] User default logged out
Re: Retrieving connection to database for pulse failed. Using Gax 8.5.220
« Reply #1 on: March 30, 2016, 01:54:23 PM »
Is the Pulse database on same DBMS server as the GAX databases? Did you check the DAP's configuration if all matches against suggested approach? Is this fresh install or any upgrade/migration?
Offline kny
« Reply #2 on: March 30, 2016, 02:21:24 PM »
Thank you for your response, this is a fresh installation. gax database is in the same dbms as pulse database, i checked all configurations on dap.
I see the Connection refused: connect, i don`t know why it cannot connect to db. My pulse collector dap connection to the db is fine. it is just the pulse jdbc that is not working.
« Reply #3 on: March 30, 2016, 04:31:56 PM »
Which DB are you using?
