Author Topic: Raise Event Block and Json String - Composer 8.1.4  (Read 2653 times)
Offline ymattica
« on: March 24, 2016, 05:48:10 PM »
System variable LAST_EVENT_MESSAGE  works only setting a simple string but not setting a Json Object ???
I'm testing a Raise Event Block on a voice application.
I created a custom event and throw it using the Raise Event Block
When I capture the event I am able tot read the LAST_EVENT_MESSAGE value only if I assign a simple string (for example, 'test') but I can not read a JSON string (for example, {"Test": "value"}.
if LAST_EVENT_MESSAGE == test  --> OK
if LAST_EVENT_MESSAGE.Test == value --> KO
Could you help me ?
Regards
Re: Raise Event Block and Json String - Composer 8.1.4
« Reply #1 on: March 24, 2016, 06:22:43 PM »
Convert the json to string maybe? As the input for the function is a string makes sense a json not be valid.
Offline ymattica
« Reply #2 on: March 24, 2016, 06:40:31 PM »
I'll do what I suggest we do even if the JSON format was very convenient for my purposes :(
Best Regards
« Reply #3 on: March 24, 2016, 06:53:34 PM »
Yes, but then on the other side you grab the string and just convert to a json object again
Offline ymattica
« Reply #4 on: March 25, 2016, 09:27:47 AM »
OK  ;)
Thanks again
