Author Topic: Genesys Administrator and 8.5 framework  (Read 2547 times)
Offline vma
« on: March 24, 2016, 09:41:20 AM »
I'm trying to use Genesys Administrator on a 8.5 Framework. Starting 8.5 the message server is able to connect to the DB just using the DAP. there is no need for a DBServer anymore. It seem though GA is not able to do that so I don't have the logs and alarms on the Monitoring page. In the 8.5 framework deployment guide it states clearly against using a DBServer. Anyone know how to go around in in GA or I'm forced in using GAX?
Mihai
Offline nonny
Re: Genesys Administrator and 8.5 framework
« Reply #1 on: March 24, 2016, 10:52:14 AM »
Did you connect everything to MS and set the option in Message Server?
Sent from my SM-N9005 using Tapatalk
Offline vma
« Reply #2 on: March 24, 2016, 12:27:54 PM »
Yes, default application is connected to message server and db_storage is set to true.
And in GAX I can see the alerts. The issue is only in GA
Cheers,
Mihai
« Reply #3 on: March 24, 2016, 01:05:15 PM »
Create a DB server for GA
