" /> Anyone has example to update transaction data in CME using cfgTransaction? - Genesys CTI User Forum
Author Topic: Anyone has example to update transaction data in CME using cfgTransaction?  (Read 3785 times)
Offline nikhiltrivedi84
Does anyone have a sample code to update Transaction Data in CME using crgTransaction? Any other method is also fine.
Offline hsujdik
Re: Anyone has example to update transaction data in CME using cfgTransaction?
« Reply #1 on: February 19, 2016, 11:01:19 PM »
I am not really a developer, so my code may be out of the usual standards... anyway find in the link below an example on how to get the CfgTransaction objects from Configuration Server.
http://owncloud.sujdik.com.br/index.php/s/NY0ZfphDmVSDWOH
To change a Transaction is simple... just retrieve it from the configuration server, make the changes to the CfgTransaction object as you wish and call the method save().
I also added a piece of code showing how to subscribe to Configuration Server notifications for when objects of an specific type change - a thing that I find very difficult due to not being a programmer.
Hope this helps
Offline JungGiCho
« Reply #2 on: February 22, 2016, 08:19:44 AM »
Below is my transaction update code with xml.
    public boolean updateAnnexOption(String pSection, String pOption, String pValue)
        Document    confObject = null ;
        String      xml = null ;
        boolean retval = true ;
        logger.info("Starts...." + pSection + "," + pOption + "," + pValue) ;
            xml =  "<ConfData>" +
                        "<CfgDeltaTransaction>" +
                            "<CfgTransaction>" +
                                "<DBID value='" + mTransactionDBID + "'/>" +
                            "</CfgTransaction>" +
                            "<changedUserProperties>" +
                                "<list_pair key='" + pSection + "'>" +
                                    "<str_pair key='" + pOption + "' value='" + pValue +"'/>" +
                                "</list_pair>" +
                            "</changedUserProperties>" +
                        "</CfgDeltaTransaction>" +
                    "</ConfData>";
            logger.info("Update annex option...." + xml) ;
            confObject = DocumentBuilderFactory.newInstance().newDocumentBuilder().parse(new InputSource(new StringReader(xml))) ;
            retval = updateObjects(CfgObjectType.CFGTransaction , confObject, null ) ;
        } catch (Exception ex) {
            logger.warning(CtiLogger.logstr("Exception....",ex)) ;
            retval = false ;
        return retval ;
    boolean updateObjects(GEnum pObjectType, Document pConfObject, KeyValueCollection pFilter)
        RequestUpdateObject message ;          // Configuration Server에 변경을 요청 객체
        Message            response ;          // Configuration Server에 변경을 결과 응답 메시지
        //TreeMap retMap = new TreeMap() ;  // Return 값 저장 변수
        logger.info("Starts...." + pObjectType + "," + pConfObject + "," + pFilter) ;
        try
            // Configuration Server가 연결이 될 때까지 기다린다.
            if( mConfServerProtocol.getState().equals(ChannelState.Opened))
                // request message를 만든다
                message = RequestUpdateObject.create(new Integer(pObjectType.ordinal()), pConfObject , pFilter);
                logger.info("RequestUpdateObject....\n"+message) ;
                // 정보 조회를 요청한다
                response = mConfServerProtocol.request(message) ;
                // 결과값이 왔는지 확인한다
                if( response == null || !(response instanceof EventObjectUpdated) )
                    // 결과값이 없거나 object를 읽었다는 Event가 아니면
                    if( response == null )
                        logger.info("RequestUpdateObject response - no object updated....") ;
                    } else
                        logger.info("RequestUpdateObject response - no object updated....\n" + decode(response.toString()) ) ;
switch(response.messageId())
                    case EventError.ID  :
EventError eventError = (EventError)response ;
if ( eventError.getErrorCode() == 29 )
mReadOnlyMode = true ;
logger.warning("Configuration server working mode is changed to Read-Only Mode....") ;
break ;
default:
break ;
                    retval = false ;
                } else
                retval = true ;
                    logger.info("RequestReadObjects response - object  updated....\n" + decode(response.toString()) ) ;
            } else
            retval = false ;
            logger.info("RequestUpdateObject response - no object updated because cfg server is not connected....") ;
            retval = false ;
        return retval;
« Last Edit: February 22, 2016, 08:22:51 AM by JungGiCho »
Offline hsujdik
« Reply #3 on: February 23, 2016, 06:15:04 PM »
I have updated the code that I have posted before, that includes changing a Transaction's Annex specified option inside a specified section, done directly on the objects by using the ConfService. At least to me (not a real developer) it is easier than using the low-level functions and xml with delta objects as our friend JungGiCho posted.
Also, one must be careful while using Delta Objects on a RequestUpdateObject, because if you send an option with the same value that already exists, it actually deletes the option instead of updating it to the same value.
