Author Topic: Can't get Brio to report in cyclic manner!  (Read 4154 times)
Tony Tillyer
I'm guessing I missed something on the CCA Course but...
When I set up a Brio query for, say, an Agent's stats and I want to send the results via Broadcast Server, to produce an Excel document from my Agent HOURLY Query only (not the whole .oce file), Brio send out the formatted report but returns the same day (6th May 2003), every day!
I'm currenly looking at the Agent HOUR level query and I can't figure out how I put in the parameters to ensure that each new day contains the figures for yesterday.
Obviously, this is the main reason for broadcasting reports in a job cycle but, like I said, I must have drifted away when this was mentioned on the course (nothing new there!)
Any help appreciated constructive criticisms also happily taken on board!
TIA
Tony
Katherine
You need to modify the filters on the report so that they use system date and not the one provided in EIS.
Marked as best answer by on September 22, 2024, 05:32:34 AM
Tony Tillyer
  • Undo Best Answer
  • Kathertin,
    OK the date the query section is using to filter on is (allegedly) the Query Date. There is no System Date in the table to pick from. I'm guessing it's something I can addin, into the criteria? There is a section for SQL, so I'm also guessing that I can put my details in there?
    You don't have any example script, do you? (fawn, fawn, grovel, grovel...)
    TIA
    John Doe
    When you set up the report in BCS you can set the Job Detail |Action|Custom Value for the limit as yesterday, today, first of the month etc.
    Tony Tillyer
    Thanks for all of your input. The solution is not that easy, but it contains a computed item to work out the date.
    I'm up to speed now, thanks!
