" /> Set value on object - Genesys CTI User Forum
Author Topic: Set value on object  (Read 2788 times)
Offline daniel_san
Set value on object
« on: January 20, 2016, 04:05:32 PM »
Somebody knows how to set a value on application Object. This object is inside -->Enviroment/Applications.
I know how to read value from configuration trough IconfigManager or IConfigurationService, but i donīt know how to set value  :-\
I tried to set value trough IConfigManager but it is setting on Agent object Annex  :'(
Some help?
Offline daniel_san
Re: Set value on object
« Reply #1 on: January 20, 2016, 05:55:16 PM »
small explanation
I can read the configuration of the application where the agent is loged with that:
CfgApplication app = _configService.MyApplication;
Inside this object i can read:
app.UserProperties
app.Options
But i canīt update a value inside. Iīm trying with set but itīs not working
app.Options.Set("key", value);
Offline daniel_san
« Reply #2 on: January 20, 2016, 06:05:55 PM »
Update:
I found [b]app.Save()[/b]  ;D
But i have no permissions. Iīll keep you informed :)
« Reply #3 on: January 20, 2016, 06:13:23 PM »
Great job :)
Good luck and thanks for sharing
Offline daniel_san
« Reply #4 on: January 25, 2016, 11:56:28 AM »
Finally it works (setting the permisions to user)
