Author Topic: GAD 7.6 custom contact overview  (Read 2017 times)
Offline peter.prusi
« on: January 12, 2016, 01:32:01 PM »
Hi community,
I have two types of contacts "A" and "B" and I have two types of Agents "A" and "B". The contact type will be stored in the UCS DB.
The idea is that Agents "A" can only see and search Contacts in GAD where the contact-type is "A". I think I have to  hide the tab, where all contacts are shown and replace it with a custom tab.
In this tab I need a custom search for contacts "A" or "B". Is it possible like this and where can I find the option for hiding a tab ? Or is there an easier way ?
The next question is : If I select a contact, is the information for this contact shown in contact tab or do I have to develop a new "own" contact tab with all functionality ?
Thank you,
Peter
Re: GAD 7.6 custom contact overview
« Reply #1 on: January 12, 2016, 04:08:29 PM »
Make the field searchable so they can choose it as a search parameter. But if you want to avoid that possibility as well then yes, custom contact search and you make the type parameter a hidden field
Offline peter.prusi
« Reply #2 on: January 15, 2016, 09:20:20 AM »
Okay, thank you for the Information
