Author Topic: Outbound on AVAYA G3 without Dialogic.  (Read 3769 times)
ecki
Hi guys,
Does anyone have experiences with this? Is it necessary to configure anything on the switch side?
Thanks...
Stephanie
We are doing a similar thing. The best person to talk to would be Vic he has helped us with setting our OCS several months ago on Avaya without the cards. To summarize, we are using something call call classifier, which allows us to bypass Dialogic cards altogether.
On a PBX side, you need to configure it to work with this call classifier, which is a major headache from what I have seen so far. My suggestion would be to make sure that your PBX team really knows how to configure it and have done it before. DO NOT ATTEMPT TO DO IT YOURSELF.
ecki
Thank you for info. I will consult this with our AVAYA team.
avtar cheema
On the switch you need a Call Classifier (CC) board to do the voice detection. Call Avaya and get info for the latest CC.
I am currently having fun and games with the Answer Machine detection option. At present the Am detection for mobiles is 50\50.
rgds
AC
Marked as best answer by on September 24, 2024, 01:09:24 PM
ecki
  • Undo Best Answer
  • Hi,
    Thank you, i allready know something about Call Clasifier, but still I am having problem with fax/modem/asm .. detection configuration.
    Could you tell me please more about this options. What is exactly neccessary to do, that the CallClasifier start to recognizing?
    Thanks.
