Author Topic: Problems trying to develop a WDE extension  (Read 3971 times)
Offline Gabi
« on: December 02, 2015, 05:25:57 PM »
Hello.
I'm trying to develop my first WDE extension (I did some work on IWS before). I created a new project on Visual Studio 2012, set WDE as the external startup project and added all the Genesyslab.* DLLs as references. I can build the project (generate), but when I try to debug it I get the following error:
[quote]Resolution of the dependency failed, type = "Genesyslab.Desktop.Infrastructure.IBootstrapController", name = "". Exception message is: The current build operation (build key Build Key[Genesyslab.Desktop.Infrastructure.IBootstrapController, null]) failed: The current type, Genesyslab.Desktop.Infrastructure.IBootstrapController, is an interface and cannot be constructed. Are you missing a type mapping? (Strategy type BuildPlanStrategy, index 3)[/quote]
Does anyone know what the problem may be?
Thanks in advance.
Re: Problems trying to develop a WDE extension
« Reply #1 on: December 02, 2015, 05:45:47 PM »
In what version of .Net did you build the project?
Offline Gabi
« Reply #2 on: December 02, 2015, 05:57:01 PM »
.Net Framework 4.5 and 4.5.1. This also happens when I try to build the Extension Sample.
Offline Gabi
« Reply #3 on: January 08, 2016, 02:26:25 PM »
Oh, I had forgotten about this thread, sorry. I "solved" this problem by switching from Windows 10 to Windows 7 and starting over.
Offline GoodONE
« Reply #4 on: April 16, 2018, 09:50:17 PM »
Was switching from W10 to W7 your fix?
I'm facing the same issue than you, but I'm in W7 so for that there's no problem, I developed my WDE extension in framework 4.5,
Any idea of what could be causing this issue?
Regards.
Offline Gabi
« Reply #5 on: April 17, 2018, 06:27:28 PM »
I'm afraid I can't tell exactly what the fix was. I do know I was running Windows 10 on a virtual machine and that was known to cause problems, so I switched to Windows 7, but I also redid the project from scratch, so there may have been a problem in the old version of the project which did not arise in the newer one, or perhaps it was, indeed, a Windows compatibility issue.
