Author Topic: Connection with VBA (Excel)  (Read 3016 times)
Offline fabricio_barcellos
« on: August 19, 2015, 02:52:28 PM »
You can create a connection to Outbound Contact Manager via Excel / VBA?
Re: Connection with VBA (Excel)
« Reply #1 on: August 19, 2015, 03:27:57 PM »
lol...no. DBServer is your software to connect to databases. Excel is not a DB
« Reply #2 on: August 19, 2015, 04:54:12 PM »
Thank you, I now have around 58 campaigns complement all and would like to generate a command to take the Excel through VBA, what and how much are the blank contacts each. It's possible?
Is there any way to connect to genesys base at exce / vba?
Right would toolkit using desktop Genesys?
« Reply #3 on: August 20, 2015, 09:28:20 AM »
If you just want to use Excel, just connect to the OCS database directly from Excel (there are connectors). Or just use any current SQL tool, which support export to CSV.
