Author Topic: Cannot Start workspace Sip Endpoint  (Read 11843 times)
Offline sergioperez
« on: July 29, 2015, 10:56:56 PM »
Men, sorry if I bother you, is just that i have the same issue as the member of this post: http://www.sggu.com/smf/index.php?topic=7166.0
When i login into Workspace Desktop Edition 8.5.106.22 i get the message: "Cannot start workspace SIP endpoint", the SIP Server is installed in Windows Server 2008 64bits (with .Net 3.5). I am trying to run the Workspace on a pc with Windows 8.1 also with .Net installed.
I appreciate your support.
Re: Cannot Start workspace Sip Endpoint
« Reply #1 on: July 29, 2015, 11:00:28 PM »
Post IWS logs
Enviado de meu C6602 usando Tapatalk
« Reply #2 on: July 29, 2015, 11:01:01 PM »
Is 8.1 supported?
« Reply #3 on: July 29, 2015, 11:03:38 PM »
Yes it is. So post logs covering the IWS startup
Also be sure Net is 4.5 on your agent side
« Reply #4 on: July 30, 2015, 11:28:02 AM »
Did you install any SIP endpoint (custom, 3rd or Genesys IWS/WDE)?
Offline Dionysis
« Reply #5 on: August 03, 2015, 02:42:01 PM »
I had similar issues with a VM, I installed, uninstalled, read logs, reinstalled dependencies, read more logs, then got frustrated, deleted the VM and started over.  Works fine now.
Interested to know if you find a solution though as reinstalling the OS from scratch is not really a solution for everyone. ;)
Offline ryusuf
« Reply #6 on: March 10, 2016, 12:47:58 PM »
I am facing a similar issue, when i installed the Workspace on Agent PCs and tried to start it. The SIP Endpoint does not start. Attaching herewith the logs.
https://www.dropbox.com/s/wiccgw0xpg34xns/InteractionWorkspace.20160310_153322_278.log?dl=0
https://www.dropbox.com/s/dmprt89107zogda/IWSIPEndpoint_1003.20160310_153407_777679.log?dl=0
I am not sure whether is a port issue. If anyone can provide an insight, it would be helpful.
Thank You
Best Regards
Rashid
« Reply #7 on: March 10, 2016, 01:01:21 PM »
What version of WDE SE are you using? Did you install the SE or just copy it?
Offline ryusuf
« Reply #8 on: March 12, 2016, 07:11:14 PM »
Hi Kubig,
The version of SE is 8.5.105.03 and Workspace is 8.5.110.13. The SIP Endpoint was installed along with Workspace on the Agent PC from the ClickOnce package.
Thank You
Best Regards
Offline nonny
« Reply #9 on: March 13, 2016, 04:08:54 AM »
Can't access the file but any Antivirus on the machines?
Sent from my SM-N9005 using Tapatalk
Offline ryusuf
« Reply #10 on: March 13, 2016, 04:17:48 PM »
Hi Nonny,
No. Antivirus and firewall is disabled on the Agent PCs.
Thank You
Best Regards
Offline hsujdik
« Reply #11 on: March 13, 2016, 07:34:58 PM »
I had this problem also with Win 10 only. On Win7 it works fine
Offline ryusuf
« Reply #12 on: April 21, 2016, 07:49:19 AM »
Dear Friends,
This issue is resolved as the prerequisites where not installed before installing Workspace and Endpoint.
The following prerequisites needs to be installed first
1. .NET Framework 4.5
2. Microsoft Visual C++ 2005 Service Pack 1 Redistributable Package MFC Security Update
3. Visual C++ Redistributable for Visual Studio 2013
And then install the Workspace and SIP endpoint. Hope this helps you all.
Thank You
Best Regards
« Reply #13 on: April 21, 2016, 09:10:58 AM »
OMG - this steps are mentioned within the deployment guide, so did you read it?
Offline Gulden_NL
    • VoxPeritus - The Voice of Experience
« Reply #14 on: April 24, 2016, 02:39:43 AM »
First, thank you for posting the root cause ryusef, you've added to the searchable knowledge here.
Second, Kubig.... This is your standard response. I'm happy for you to work in such a tiny, static (boring) place.
I returned here back in January because I'm up to my eyebrows in Genesys. Nothing but Genesys and Cisco. Over the last three to five years, I've stayed involved with Genesys but I've been involved in many other pieces, mainly architectural.
I saw your and Cav's responses belittle many of the posters, and was surprised given Cav's previous attitude of being very helpful and open to all posters.
No idea about this guy's personal situation, but many of us working extremely large and/or Dynamic environments. I'm currently working with a Genesys/Cisco architecture with 2,138 servers as of yesterday. The responsibility for desktop is in another group who have at least 110,000 desktops to manage
Sent from my Nexus 6 using Tapatalk
