Author Topic: PSDK Java CRUD  (Read 2422 times)
Offline casmat
PSDK Java CRUD
« on: June 22, 2015, 08:07:09 PM »
Im new to the PSDK and im trying to make a basic CFGTransaction CRUD on java, Im following the steps of the documents, I Could establish the connection but i dont understand how to create the object or how to use the method, I dont know if you could give me any working examples of this topic, doesnt have to be CFGTransaction.
Re: PSDK Java CRUD
« Reply #1 on: June 23, 2015, 08:17:18 AM »
Do you want to create object of Transaction type (List Object,...) or what exactly do you want to achieve?
Offline casmat
Re: PSDK Java CRUD
« Reply #2 on: June 23, 2015, 03:02:14 PM »
I want to develop a CRUD for a CFGTransaction with its sections and each of them with its options using the SDK for Java. Thank you for the fast reply.
