Author Topic: media type auto answer  (Read 12497 times)
Offline daniel_san
« on: May 25, 2015, 05:08:28 PM »
I can see the auto answer for each channel on interaction workspace annex of configuration manager.
*voice.auto-answer
*email.auto-answer
[b]*outbound.push-preview.auto-answer[/b]
There is no option for the pull preview interactions to set auto answer?
Something like... [b]outbound.pull-preview.auto-answer[/b]
Re: media type auto answer
« Reply #1 on: May 25, 2015, 08:29:56 PM »
What? No because in that model calls are invoked by agent and shown on IWS by default...
What you say is redundant and illogical.
Offline daniel_san
« Reply #2 on: May 26, 2015, 08:21:41 AM »
[quote author=cavagnaro link=topic=8870.msg39540#msg39540 date=1432585796]
Thank you for your response cavagnaro.
I donīt know if it is ilogical. Let me explain:
[b]PUSHPREVIEW(campaign)[/b]
In this type of campaign, when you press the button "get record" on campaign tab, desktop shows toaster to accept or reject the interaction. If you disable variable [b]outbound.pull-preview.auto-answer[/b] on configuration the toaster doesnīt appear and interactions comes up directly.
[b]PULLPREVIEW(Rescheduled records)[/b]
The same behaviour, without the button "get record". The OCS sends you interaction. The Desktop shows the toaster to accept or decline the interaction. I want to disable this toaster. I realized there is no variable on configuration like [b]outbound.pull-preview.auto-answer[/b] with pull instead of push.
As a conclusion. I need to disable the toaster on Rescheduled interactions, like we do on PushPreview interactions.
Please, feel free to correct whatever i have written wrong.
Thank you in advance.
« Last Edit: May 26, 2015, 08:23:46 AM by daniel_san »
« Reply #3 on: May 26, 2015, 11:37:51 AM »
It is because as it states, is for rescheduled records, what if your agent is with another call or interaction?
Offline daniel_san
« Reply #4 on: May 26, 2015, 12:06:49 PM »
[quote author=cavagnaro link=topic=8870.msg39547#msg39547 date=1432640271]
Yes, for rescheduled records (pull preview i suppose). It doesn't matter if the agent itīs working with another interaction, it will be fine if the new rescheduled interaction itīs opened automatically on another interaction.
When toaster appears itīs not calling any chain of command. When the agent press the button call chain of command to open it (or reject it).
« Reply #5 on: May 26, 2015, 12:09:53 PM »
Remember rescheduled records have in theory a window to be called to. If agent does accept while on another call which you don't know the length it will have, you may lose a contact. Also, those records have a life span, which expire after a while. Then you control them by treatment. Imagine an agent with 3 records on his screen...what would happen then?
Offline daniel_san
« Reply #6 on: May 26, 2015, 01:43:14 PM »
[quote author=cavagnaro link=topic=8870.msg39549#msg39549 date=1432642193]
Remember rescheduled records have in theory a window to be called to. If agent does accept while on another call which you don't know the length it will have, you may lose a contact. [b]Also, those records have a life span, which expire after a while. Then you control them by treatment. Imagine an agent with 3 records on his screen...what would happen then?[/b]
Yes, we are controlling this time to accept the interaction.
The problem is the Agent can have a big number of reschedule for the same time. Once this time comes, the rescheduled records will appear on toasters.... If you have 15 rescheduled records, the agent have to press the button 15 times. And the time of pressing 15 times this button itīs time lost for Business...
[b]Imagine an agent with 3 records on his screen...what would happen then?[/b]
The same if i have accepted the previous15 rescheduled interactions of the example, i suppose.
Any idea?
Thank you very much for your time.
« Last Edit: May 26, 2015, 01:45:23 PM by daniel_san »
« Reply #7 on: May 26, 2015, 01:45:19 PM »
And he handles those 15? O.o is that humanly possible? What about next ones? Is this a worst scenario or a standard one? Personal or Group reschedules?
Offline daniel_san
« Reply #8 on: May 26, 2015, 01:49:26 PM »
[quote author=cavagnaro link=topic=8870.msg39555#msg39555 date=1432647919]
Personal reschedules. Itīs something usual...
I think that itīs not bad. The agent have some interactions for a lot of time....
« Reply #9 on: May 26, 2015, 02:11:25 PM »
It is not logical to use "auto-answer" function for pull preview campaigns, where the interactions has to be dialed from an agent. So, it cannot be answered before is dialed  :) The only way, how to achieve your goals, is through the custom module within IWS/WDE.
BTW: I am using IWS/WDE and have not encountered the toaster with accept/reject for pull preview campaigns (should by caused by configuration, but I have all allowed).
Offline daniel_san
« Reply #10 on: May 26, 2015, 04:40:21 PM »
[quote author=Kubig link=topic=8870.msg39558#msg39558 date=1432649485]
But, itīs the same behaviour in preview campaigns. The agent have to dial on each interaction opened. I am not understanding what is the difference of reschedule and push or pull to auto accept  ???
I tried with Toaster and Broadcast class, but it doesnīt work.
Thank you for your time.
« Reply #11 on: May 26, 2015, 06:34:58 PM »
It is not true that the behavior is the same. In general, in out-of-box IWS version there is no way how to achieve auto-dial (no auto-answer) - only through the custom module. It becomes from OCS solution design for preview, where the agent must decide whether the customer will be dial or not. All is described in documentation very well.
Offline daniel_san
« Reply #12 on: May 27, 2015, 12:36:50 PM »
[quote author=Kubig link=topic=8870.msg39570#msg39570 date=1432665298]
Yes iīm not talking about auto dial. The agent will dial on each interaction.
What i was trying to say is:
In Preview campaigns. You can presh the button "Get Record" a lot of times. You will have lot of interactions opened (not dialed).
In pull preview (rescheduled), agent have to accept the reschedule pressing the accept button.
Offline daniel_san
« Reply #13 on: May 28, 2015, 08:52:32 AM »
I was trying someting.  ???
Iīm suscribed to events of campaign. When a Rescheduled interaction comes to desktop iīm trying to open with
[b]_container.Resolve<ICommandManager>().GetChainOfCommandByName("StartPreviewRecordOutbound").Execute(parametersStart)[/b]
I can see in genesys documentation, this chain have no parameters. http://docs.genesys.com/Documentation/IW/8.1.3/Developer/Outbound
Iīm trying to construct the call to chain like the worskpace desktop do. But itīs not working 100% for me. Some help? :)
« Reply #14 on: May 28, 2015, 11:24:30 AM »
Pull preview has nothing to do with "reschedule". From my point of view, the auto-answer on voice preview campaigns does not make a sense.
