Author Topic: DBServer use from SDK  (Read 2580 times)
Offline Timur Karimov
« on: May 21, 2015, 07:42:21 PM »
Hi all.
I mess something or PSDK really hav't the standard way to use the DB Server connection(direct or throw DAP) to execute the sql request in the real database?
WBR Tim
Offline gstkein
Re: DBServer use from SDK
« Reply #1 on: May 26, 2015, 01:10:55 PM »
Iīve never found a way to do that but you probably shouldnīt be using DBServer protocol anyway since itīs been retired.
http://docs.genesys.com/Documentation/RN/8.5.x/psdk-java85rn/psdk-java8500013
DB Server Protocol - This protocol has been retired, as the DB Server component has been retired.
Offline gstkein
« Reply #2 on: May 26, 2015, 01:20:18 PM »
Before 8.5 I think it was called Platform SDK Data Access protocol
