" /> Disable/Enable HoldCall command - Genesys CTI User Forum
Author Topic: Disable/Enable HoldCall command  (Read 3282 times)
Offline dainese82
« on: May 20, 2015, 08:34:52 AM »
how can I disable the command "HoldCall " for the first 30 seconds of the call?
Thanks a lot
Re: Disable/Enable HoldCall command
« Reply #1 on: May 20, 2015, 10:51:38 AM »
Just through IWS/WDE customization.
Offline dainese82
« Reply #2 on: May 20, 2015, 12:35:47 PM »
Hi Kubig,
I did not find any example in the documentation provided by genesys :(
« Reply #3 on: May 20, 2015, 03:06:05 PM »
;D ;D ;D
Doubt there is a sample for each idea a customer has...
It is more generic code rather than Genesys SDK one.
Offline mcruli
« Reply #4 on: February 22, 2016, 05:41:30 PM »
Put a new chain for the Hold Command. And make a timer for enable this..
Offline luchosrock
« Reply #5 on: March 11, 2016, 04:24:10 PM »
What are you using? IWS? GAD? Custom solution with Platform SDK? Or are you trying to force the delay on the Server side?
