Author Topic: IWS - Disposition View  (Read 4422 times)
Offline obegendi
« on: April 15, 2015, 07:36:52 AM »
Hello everyone,
I'm trying to replace a existing view on IWS. I tried to create a view for DispositionDetailsRegion i register it in main initialize method, but i couldn't control disposition code combobox. I'm actually trying to do action depends what selected on that combobox. I think that combobox default for IWS outbound, am i right ? Combobox contains; Answer, Unknown call result, fax, wrong party ....
If agent select answer i want to show my custom survey form, if select another thing see nothing. I looked in my interaction event handler's object (e.value) then dispositioncode was NULL, also i tried IDispositionCode on desktop.outbound but i couldn't anything useful. If i can catch when selected on that combobox, like on standart wpf combobox element's selection_changed event, its gonna be perfect for me. I read all document about view but nothing useful, please tell me how can i do this ? What is the best method for this?
Thank you.
Re: IWS - Disposition View
« Reply #1 on: April 15, 2015, 10:49:17 AM »
The view with disposition codes is not related just to the outbound calls, but to all types of interactions. The view/window with combo box (Answer, Unknown call result) is related to campaign calls, where the view/region is different from the above with disp. codes. So, I think you have selected wrong region for your custom module.
Offline obegendi
« Reply #2 on: April 15, 2015, 05:15:31 PM »
Is it wrong ?
container.RegisterType<IDispositionCodeView, DispositionCodeExView>();
I just want to control that default disposition combobox.
« Reply #3 on: April 16, 2015, 05:53:09 AM »
It is right - for disposition codes region - you can find similiar sample within IWS/WDE package.
Offline obegendi
« Reply #4 on: April 16, 2015, 09:44:24 AM »
Is it possible to control that default combo or control view (dispositiondetailsregion) ? Or just catch selection_changed evet that combo, but how ?! ???
« Reply #5 on: April 16, 2015, 10:29:14 AM »
Do not understand what you want to achieve - replace default DispositionCode view or change behavior of default disposition codes?
Offline obegendi
« Reply #6 on: April 16, 2015, 11:05:02 AM »
Hello again,
I want to control that view. Actually if i can delete/remove view a region, this gonna be great. Is it possible to remove a region ?
Like this maybe ?
viewManager.ViewsByRegionName["InteractionDetailsDispositionsRegion"].Remove(new ViewActivator() { ViewType = typeof(IDispositionCodeView), ViewName = "DispositionCodeView" });
But its not working i guess, also there is a deactivemethod and remove method in viewmanager object. But i couldn't run this either.
viewManager.DeactivateViewInRegion(parentview, "InteractionDetailsDispositionsRegion", "DispositionCodeView");
What is really parent view ? it seems like a object, but i didn't see anything before like parentview object ? What is the proper using this ? Can you help me little bit ?
