Author Topic: Chat app using PSDK 8.5  (Read 6624 times)
Offline rajkishor09
« on: April 14, 2015, 02:31:29 PM »
I am building a web based chat app where agent and customer can chat with each other. I have searched a lot for an example which will give me correct Request & Response sequence but couldn't get. Can anyone help me on this? What I am looking for :
[list]
[li]Request & Response sequence for Customer facing app (I came to FlexChat should be used here)[/li]
[li]Request & Response sequence for Agent app (Looks like BasicChat will help here)[/li]
[/list]
I want to know what should be the ideal sequence from Interaction Server to Chat server in both case. In code sample will help greatly.
Re: Chat app using PSDK 8.5
« Reply #1 on: April 14, 2015, 02:56:11 PM »
From my point of view, the better "hello world" sample is from WebAPI samples package, which is available for release 8.1 (but there are no mandatory changes between these version).
Offline rajkishor09
« Reply #2 on: April 14, 2015, 03:02:38 PM »
Thanks for reply,
What about agent side ? Customer facing app looks straight forward to me but Agent side Interaction Server, UCS, Chat etc are there. What should be the login & request sequence to these server?
I have trying to figure out that part from last 5 days.  :(
« Reply #3 on: April 14, 2015, 03:16:18 PM »
As I wrote, the best pattern/template is from WebAPI samples where you can find all mandatory requests.
Offline PeteHoyle
« Reply #4 on: May 01, 2015, 11:10:23 AM »
If you are using WebAPI Server v8.5 you can use the Genesys Chat Configuration Widget to generate the code for the customer side chat app.
http://docs.genesys.com/Documentation/ES/8.5.0/WebAPIDEV/ChatWidget
Offline gstkein
« Reply #5 on: May 06, 2015, 02:27:18 PM »
For the Agent Side you can use this example
CHAT client example
https://mega.co.nz/#!c8ZQ1SrY!EiXrOYRIAE6U4oHxXjg_t3IQpUdQ5OGogtE8LNeA48s
Offline gstkein
« Reply #6 on: January 26, 2016, 01:01:30 PM »
Updated link
https://mega.nz/#!R4JUCC6I
« Reply #7 on: June 22, 2016, 03:46:58 PM »
[quote author=gstkein link=topic=8794.msg42084#msg42084 date=1453813290]
Updated link
Need a decryption key?
Offline mkanan94
« Reply #8 on: June 22, 2016, 07:07:34 PM »
I can't access either one of those links. Was anyone able to download it and if possible post the source here?
Offline gstkein
« Reply #9 on: July 12, 2016, 06:09:52 PM »
Re up https://mega.nz/#!No52VQSZ!7qxTrdjm5oQ5ZMUjyEe8fQ0IbjPV9zvUdCrL5b6gZZw
« Reply #10 on: July 12, 2016, 09:14:38 PM »
Thanks!
