" /> main mask failed - Genesys CTI User Forum
Author Topic: main mask failed  (Read 2893 times)
Offline S2H
main mask failed
« on: April 03, 2015, 08:15:28 PM »
I have built a ccpulse view. In that one of the stat is total short abandoned calls. I have built the metric    mainmask- call abandoned, call abandoned from ringing. Category- total numberintimerange, subject- dn action, objects- queues. But it shows as mainmask failed in ccpulse. Please help regarding the issue
Adam G
Re: main mask failed
« Reply #1 on: April 03, 2015, 08:31:59 PM »
What have you defined for your TimeRange?
Offline S2H
« Reply #2 on: April 04, 2015, 12:06:37 PM »
Thanks for your reply. I have default, Growing time profile. In which and all scenarios i will get mainmask failed error.
Adam G
« Reply #3 on: April 04, 2015, 12:20:32 PM »
Generally; I would check each of the details in cfg/CIM/StartServer to make sure that there are no anomalies or items missing.
Specifically; If you have a "default" set anywhere - make sure that "default" has actual values - and make sure that it has not been left unconfigured with "null" values.
HTH?
Offline S2H
« Reply #4 on: April 04, 2015, 01:06:23 PM »
whether i need to check the  statserver logs regarding this.
Adam G
« Reply #5 on: April 04, 2015, 01:28:46 PM »
HTH?
