" /> CCA Agent login logout time stamp report - Genesys CTI User Forum
Author Topic: CCA Agent login logout time stamp report  (Read 5210 times)
Zilan
Hi everybody,
Is it possible to pull actual time of agent login and logout as a BRIO custom report
Roger
  • Hi,
    Did you ever find an answer to this?
    I would like to know also.
    Declan O'Mahoney
  • Yes, this is posssible by using the login table. You can setup a DAP for your reporting statserver that feeds datasourcer and point it to the datamart. Create the login table in the datamart and then you can create a view to link this to an agent report for brio. I have done this before for a 100 seat call centre and it just needs some DBA maintence on the table from time to time.
