" /> Disconnected - Genesys CTI User Forum
Author Topic: Disconnected  (Read 3505 times)
Offline Ali
  • Haunted by Genesys
    • My Web Site
Disconnected
« on: February 11, 2015, 10:00:52 AM »
Hi all,
I would like to learn your opinions on how to detect TServer disconnect (or communication failure with TServer) for Protocol Management Service Implementation.
Using the following code segment, I get connected to the TServer:
[code]
this.ctiServerConfiguration = new TServerConfiguration(
EventCollectorConfig.getInstance().getConf().getCTI()
.getAppName());
this.ctiServerConfiguration.setUseAddp(true);
this.ctiServerConfiguration.setAddpServerTimeout(10);
this.ctiServerConfiguration.setAddpClientTimeout(10);
this.ctiServerConfiguration.setClientName("EVENT_AGG_SERV");
              URI ctiURI = null;
ctiURI = new URI("tcp://"
+ EventCollectorConfig.getInstance().getConf().getCTI()
.getHost()
.getPort());
this.ctiServerConfiguration.setUri(ctiURI);
} catch (URISyntaxException e) {
throw e;
this.pmsi = new ProtocolManagementServiceImpl();
this.pmsi.register(this.ctiServerConfiguration);
// Initialize event broker
mEventBrokerService = BrokerServiceFactory.CreateEventBroker(pmsi
mEventBrokerService.activate();
// Open connection with T-Server:
this.pmsi.getProtocol(
.getAppName()).open();
logger.info("[GenesysAsynchEventReceiver][Open][Event Broker Service is active and open]");
} catch (ProtocolException e) {
throw e;
} catch (IllegalStateException e) {
throw e;
} catch (InterruptedException e) {
throw e;
} catch (Exception e)
throw e;
}[/code]
Thank you in advance.
Regards,
Ali
Offline gstkein
Re: Disconnected
« Reply #1 on: February 12, 2015, 04:28:50 PM »
Since you are using ProtocolManagementServiceImpl you can add a ChannelListener to it.
a ChannelListener must implement
public interface ChannelListener extends Listener {
public abstract void onChannelOpened(EventObject eventobject);
public abstract void onChannelClosed(ChannelClosedEvent channelclosedevent);
public abstract void onChannelError(ChannelErrorEvent channelerrorevent);
this.pmsi.addChannelListener(channelListener);
that should alert you of some disconnections.
You can also catch exceptions when making request to the TServer, which sometimes mean that the protocol is disconnected.
this.tServerProtocol.send(request);
return uniqueId;
catch (ProtocolException protocolException)
if ("Connection is not opened".equals(protocolException.getMessage())) {
//YOU ARE DISCONNECTED
Also listen to the EventLinkDisconnected event.
Offline Ali
    • My Web Site
Re: Disconnected
« Reply #2 on: February 13, 2015, 01:08:57 PM »
Dear gstkein,
Thank you very much. This is what I am looking for.
Cheers,
Ali
