" /> CCPulse configuration - Genesys CTI User Forum
Poll
i want to show userevent in ccpulse
configured the userdisp stat in ccpulse stat server
1 (50%)
real time view
1 (50%)
Total Members Voted: 2
Author Topic: CCPulse configuration  (Read 2905 times)
Offline rht.jedhe
« on: January 20, 2015, 07:43:54 AM »
Hi All,
Please help me how can i show the userdisp option in ccpulse real time monitoring.
below are thing that i have done at configuration level.
Requirement is need to show the manual call connect and non connect count.
created filter using below stat.
( PairExist("GSW_CAMPAIGN_NAME", "Manual") ) & ( PairExist("GSW_AGENT_REQ_TYPE", "UpdateCallCompletionStats") ) & ( PairExist("cti_CallConnectFlag", "true") )  ( PairExist("cti_CallConnectFlag", "true") )
but in ccpulse statserver there is option userdisp under this only it will be visible, that i am not able to see.
Please help me on this.
Regards,
Rahul Jedhe
Adam G
Re: CCPulse configuration
« Reply #1 on: January 20, 2015, 09:06:44 AM »
Hi Rahul,
1.  Please post questions in the "Discussion" Forum.
2.  Your Filter appears to be missing an [i]ampersand[/i];
(PairExist("GSW_CAMPAIGN_NAME", "Manual")) & (PairExist("GSW_AGENT_REQ_TYPE", "UpdateCallCompletionStats")) & (PairExist("cti_CallConnectFlag", "true")) [b]&[/b] (PairExist("cti_CallConnectFlag", "true"))
3. Your Filter contains the same KVP, twice;[i] (PairExist("cti_CallConnectFlag", "true"))[/i]
4. If [i]userdisp [/i]the name you gave to the Compound Stat in the StatServer Options, it should be available when you build a View in CCP+.  Check you are trying to apply it to the right type of "Object" (in CCP+), by looking at the "Subject" (in StatServer).
HTH?
