Author Topic: Deployment tab is not displayed in Genesys Administrator  (Read 2596 times)
Offline aravind_mano
« on: October 06, 2014, 10:39:25 AM »
The deployment tab is not displayed in Genesys Administrator 8.1.3.  The Deployment agent service is up and running state. Which document do i need to refer to resolve this?
Re: Deployment tab is not displayed in Genesys Administrator
« Reply #1 on: October 06, 2014, 11:25:13 AM »
Check the role settings for specific user
« Reply #2 on: October 06, 2014, 12:21:01 PM »
I am using  'default' user account to login into Genesys Adminstrator. The user has full access to "Genesys Administrator" product. However, I noticed that the "Deployment" module is not listed in role permissions.
« Reply #3 on: October 06, 2014, 12:29:35 PM »
Thanks Kubig. I figured out the problem. The deployment tab will be enabled when GAX is installed.
