Author Topic: Getting fault 105 while inserting data for missed call.  (Read 4203 times)
Offline o0k00l
« on: October 01, 2014, 10:21:22 AM »
I am trying to use add record feature for abandon calls in URS.
while implementing same getting below error in interaction server logs:
FaultCode' [int] = 105
'FaultString' [str] = "No CampaignGroup found"
PLZ help...
« Last Edit: October 01, 2014, 12:08:45 PM by o0k00l »
Re: Getting fault 105 while inserting data for missed call.
« Reply #1 on: October 01, 2014, 03:04:48 PM »
Campaign must be active and configured correctly
Offline o0k00l
« Reply #2 on: October 06, 2014, 08:03:04 AM »
yes have checked, campaign is active & configured properly.
« Reply #3 on: October 06, 2014, 08:46:02 AM »
How do you add record within strategy? Post the details, the error should be there, I guess
Offline o0k00l
« Reply #4 on: October 06, 2014, 10:09:51 AM »
[quote author=Kubig link=topic=8535.msg37578#msg37578 date=1412585162]
PLZ find the screenshots of setup
Routing : - [img width=640 height=335]http://i58.tinypic.com/f207zl.png[/img]
Assign data : - [IMG]http://i57.tinypic.com/2i9195k.png[/img]
Add record : - [img width=301 height=480]http://i61.tinypic.com/6s708z.png[/img]
« Last Edit: October 06, 2014, 10:13:11 AM by o0k00l »
« Reply #5 on: October 06, 2014, 11:26:53 AM »
The CampaignGroup parameter is in incorrect format. Chech the name and format in CME/GA and copa/paste it to the AddRecord block.
Offline o0k00l
« Reply #6 on: October 07, 2014, 04:45:24 AM »
[quote author=Kubig link=topic=8535.msg37583#msg37583 date=1412594813]
Thanks for highlighting, however after changing campaign groupname issue still persists.
'CHAIN_N' [str] = "1"
        'CHAIN_ID' [str] = "1"
        'RECORD_ID' [str] = "2"
        'CampaignGroup' [str] = "Test_sa@Test_sa"
      'FaultCode' [int] = 105
[img width=640 height=310]http://i62.tinypic.com/xcrcs7.png[/img]
« Last Edit: October 07, 2014, 07:41:13 AM by o0k00l »
Offline o0k00l
« Reply #7 on: October 10, 2014, 06:26:46 AM »
Anyone with any ideas ??
Offline Fra
« Reply #8 on: October 10, 2014, 09:17:35 AM »
From the Universal Routing 8.1 Reference Manual:
Returned Results for the Add Record Object
>FaultCode value 105
>FaultString value Invalid Request
>Description Data Some mandatory parameters are missed.
Can you try to populate also Call Time and Date Time and then post the URS log snippet please?
Fra
« Reply #9 on: October 10, 2014, 10:56:49 AM »
Try to add record through GUI (GA/GAX or OCM) and look at the OCS logs which parameters and their format is used.
