Author Topic: Arithmetics in IRD  (Read 2202 times)
Offline water235
Arithmetics in IRD
« on: September 29, 2014, 07:01:16 PM »
Just that I m curious, is there anyway I could perform a modulo operation in IRD,
like
1. get a count
2. if count >12, perform count%12, and set it to be the value of count, and perform further routing >
Thanks for any pointers/help
Offline terry
Re: Arithmetics in IRD
« Reply #1 on: September 29, 2014, 09:53:33 PM »
IRD "by default" uses language where there is no built in modulo operation.
Instead when working with integer types (variables of type INTEGER) it generates "integer ariphmetic" "machine instructions", so X mod Y is the same as X - (X/Y)*Y or something like count= count - (count/12)*12
Offline water235
« Reply #2 on: September 30, 2014, 02:50:29 PM »
Thanks, this is much easier.
I did it by another way -
i did a sequencial subtraction(dividend = divend - divisor) until divisor is less or lesser than equal to dividend, increasing the quotient count by 1!
in the end reminder = dividend, there by obtaining the quotient and reminder!
