Author Topic: Problème de DN  (Read 2592 times)
Offline Gattuso
Problème de DN
« on: September 08, 2014, 04:15:22 PM »
Bonjour à vous,
jai un problème avec IWS à chaque connexion
j'ai ce message d'erreur qui s'affiche "Impossible d'enregistre le DN"
Merci d'avance
Re: Problème de DN
« Reply #1 on: September 08, 2014, 04:58:35 PM »
1. Post in English even if as French you hate it...  ;D Seriously, at least take that job
2. Post logs
Offline Gattuso
Re: Problème de DN
« Reply #2 on: September 15, 2014, 04:36:12 PM »
Hello to you
I have a problem with IWS EVERY connection
I HAVE THIS Who Error message appears "Can not Save the DN"
Thank you in advance
Re: Problème de DN
« Reply #3 on: September 15, 2014, 07:18:08 PM »
Provide Full permissions to agents folder to the IWS user group.
Follow the IWS Deployment step by step, mostly the permissions setup.
Offline Gattuso
Re: Problème de DN
« Reply #4 on: September 25, 2014, 09:28:14 AM »
I copy the file to a host computer that does not issue DN and paste into other computers it works then did declare extension
thank you for your help
