Author Topic: Does GVP support chinese userdata  (Read 2766 times)
Offline charles.x
« on: August 27, 2014, 03:11:27 AM »
When useing Play appliaction block in URS,
is it possible to deliver Chinese userdata from urs to GVP and deliver from GVP to urs?
Re: Does GVP support chinese userdata
« Reply #1 on: August 27, 2014, 05:00:13 AM »
What says documentation?
Offline charles.x
« Reply #2 on: August 27, 2014, 09:35:41 AM »
[quote author=Kubig link=topic=8491.msg37373#msg37373 date=1409115613]
As I know the TLib can support chinese userdata,but the sipserver deliver userdata to GVP with sip message.
I find a solustion in genesys website
The situation is that X-Genesys header is a part of SIP and not T-lib and therefore controlled by RFC.
According to the RFC 3261, Header Field Format: Header fields follow the same generic header format as that given in Section 2.2 of RFC 2822.
Each header field consists of a field name followed by a colon (":") and the field value.
      field-name: field-value
RFC 2822 defined the rules: A field name MUST be composed of printable US-ASCII characters (i.e., characters that have values between 33 and 126, inclusive),except colon. A field body may be composed of any US-ASCII characters, except for CR and LF.
It looks like the attached data in our case is Chinese characters in either GB2312 or GB18030 encoding which is not supported.
« Reply #3 on: August 27, 2014, 09:54:35 AM »
You can contact support for sure about this statement, but it seems the SIP does not support them
Offline charles.x
« Reply #4 on: August 27, 2014, 10:17:25 AM »
[quote author=Kubig link=topic=8491.msg37376#msg37376 date=1409133275]
thanks
