" /> Web softphone using SIP point SDK - Genesys CTI User Forum
Author Topic: Web softphone using SIP point SDK  (Read 2756 times)
Offline rajkishor09
« on: August 25, 2014, 09:38:53 AM »
Is it possible to develop Web based softphone with Genesys SIP point SDK? Anyone has experience in building such app or any suggestion on web based softphone.
Re: Web softphone using SIP point SDK
« Reply #1 on: August 25, 2014, 09:44:00 AM »
All is possible, if you know how. From SDK point of view, it is not important if the application is web-based or Winform for example. Important is the integration level and used language.
Offline rajkishor09
« Reply #2 on: August 25, 2014, 10:01:13 AM »
I was wonder how voice will be transmitted to client system using web browser. I am going to use C# language.
« Reply #3 on: August 25, 2014, 11:49:19 AM »
Voice? No. That is SIP SDK or depend on your PBX. Genesys SDK is just CTI Events for Genesys.
Offline genesysguru
    • Genesys Guru Blog
« Reply #4 on: August 25, 2014, 02:50:31 PM »
Think he is referring to the SIP endpoint SDK ... not sure how that can be embedded within a web based application other than a downloaded applet etc.
