" /> GA Solution Showing Started when App stopped - Genesys CTI User Forum
Author Topic: GA Solution Showing Started when App stopped  (Read 2208 times)
Offline PFCCWA
« on: August 21, 2014, 01:40:22 PM »
We have set up solutions in GA to enable dashboard monitoring.
However when a backup application (within solution) stops, the solution remains showing as Started.  Only if the primary app stops does solution (temporary) say Stopped before showing as Started again.
If only one app of pair (pr or bk) exist in solution, and stops then solution shows stopped.
Is this working as designed?
or are we missing configuration somewhere?
thanks.
Re: GA Solution Showing Started when App stopped
« Reply #1 on: August 22, 2014, 04:47:00 AM »
It is working as designed, unfortunately.
