Author Topic: SIP softphone using PSDK 8.1  (Read 2284 times)
Offline rajkishor09
« on: July 30, 2014, 06:39:14 AM »
I was just wondering can we build SIP softphone using PSDK 8.1 or we need "SIP Endpoint SDK. I was going through some post on this forum and Kubig mentioned that he developed one using PSDK long back. I need starting point if it is supported by PSDK  >:D.
!!! Post which I am referring.
[url=http://www.sggu.com/smf/index.php?topic=7971.0]http://www.sggu.com/smf/index.php?topic=7971.0[/url]
Offline msh
Re: SIP softphone using PSDK 8.1
« Reply #1 on: July 30, 2014, 11:28:14 AM »
If you are using a seperate SIP phone (either virtual or physical) you can do a agent desktop using only the platform SDK.
If the application needs to implement a actual SIP softphone the platform SDK is not enought.
