Author Topic: Nortel MeridianGenesys Documentation?  (Read 5227 times)
Tony
Does anyone have any docs on configuring Genesys 6.5 with the
Nortel Meridian?
Any info would be greatly appreciated!
Tony
Ralph
Most of the information is available in the TServer for Meridian 1 documentation provided by Genesys. Do you have the manual and did you read through it?
Besides this: If you do have any special questions do not hesitate to ask: We have G6.5 running at 8 locations, each one with an M1 switch.
// Ralph
Tony
Hi Ralph,
I do not have the manual, but if someone has it and could email it to me that would great.
Tony
PapaBear
What do you want to do?
PapaBear
Hi, Tony, unfortunately, we cannot do it. It would be against our contract with our vendors, but, there should be nothing wrong with us helping you with your questions. What would you like to know? I have installed several multisites using symposium tserver and urs so shoot!
Marked as best answer by on Today at 01:24:04 PM
Fabio
  • Undo Best Answer
  • Hi
    I need (if possible) configure a telephone in a multi queue.
    Is possible with Meridian ???
    Thank you
    Marco
    Ralph,
    I saw you response on the Tserver discussion Forum on Nortel Meridian
    problems.
    And I have a question about a 81C Meridian Rls 25.15 in combination with
    Symposium Express 3.0 an Genesys 6.5.
    Every time we do a sysload on our machine we have problems
    to log on with the desktop on the 3820 phones.
    If we have that problem, we unwire the phone for a moment and then
    the problem is solved.
    But its not the right way to do this as you know.
    So maby you know this problem and have a solution for it.
    Thanks and with kind regards
    Marco
    Mikael Jansson
    Hi !
    The problem with sysload on Meridian is that when the switch is reloaded all "accuired" resources get a new "accurie id", and you need to restart tserver.
    Se the following respons from Nortel.
    The Host application needs to re acquire all needed resources after the
    event: LinkStatusReport with status 06 (Link UP)
    Because M1 loose association ID in this case. (e.g. power off /reboot
    /sysload/network: tcp ip problem)
    So third party application need to resynchronize data with M1 and get a new
    ressource ID.
    At this time, you need to reboot the Genesys system manually, but this kind
    of issue can be done automatically.
    For more information you can Join Nortel Networks Developer Program.
    Go to the Developer Program web page <
    http://www.nortelnetworks.com/prd/dpp/index.html> for information about the
    program and online membership forms.
    Thirdparty developers, should contact the CTI (Computer Telephony
    Integration) group by email at nt4cti@nortelenetworks.com
    However, for membership benefits and assistance, thirdparty developers
    must belong to the Developer Program.
    Note: Nortel Networks Customer Support does not support thirdparty
    interfaces.
    Regards Mikael
